Upgrade Ciscoprime Infrastructure from 3.3.0 to 3.6
shuja_abbas_jlr
I am planning to upgrade cisco prime infrastructure from 3.3.0 ( virtual ) to 3.6 . Please assist with the steps on the upgrade .
5 Replies 5
Leo Laohoo
You are better off backing-up the DB and then importing it to a freshly installed 3.6.
can you guide on the steps to migrate the DB , does this also migrate the maps on the current prime version ?
If the DB is backed up, the map is included.
Hi ,
can you guide me how to take backup of DB ?
Kindly read the Release Notes for 3.6 because it will contain instruction(s) on how to do a DB backup.
