API for registering Umbrella Mobile Devices
webbtc
Is there a API that would allow us to bulid a self service provisioning for mobile devices? Or at least have them enter their email and kick off your provisioning process?
If I use the same link for all devices, they will all show-up as the same user correct?
What is they best way to mass provision in this case? THanks
tom1
Hi there,
Unfortunately, there is no API available to self-provision mobile devices.  And you are correct, If you use the same link to provision, they will all end up with the same profile.  With regards to mass provisioning, unfortunately, there isn't a way to do so.
