Block pornography
sdharminder889
I changed my android sms server through an app and then delete that app. I make an account of open dns. Go to link that sent to my id and add network. Changed my settings to block pornography but still porn sites are not block. What to do?please help.
15 Replies 15
rotblitz
Level 6
Level 6
What is an "android sms server"?  What app did you use to change it?
Or did you mean to say "DNS server"?  What DNS resolver addresses did you choose?  To block pornography you should have selected the FamilyShield addresses 208.67.222.123 and 208.67.220.123.  You even do not need to manage an account or a dashboard to block pornography.
Now, after all, are you using OpenDNS at all?  Visit http://welcome.opendns.com/ with your Android device.
sdharminder889
I have used DNS changer app and used 208.67.222.222 and 208.67.220.220.
At starting open Dns working very well but after a few days it did not. But still porn sites were never blocked.
I have read page about family shield but I did not understand how to use it on android phone. please help.
I want to use it without wi fi . I want to use it on cellular network.
Is there no need to have open dns account or dashboard to use family shield?
rotblitz
Level 6
Level 6
OpenDNS' dashboard is solely for networks you own, not for your devices in other networks, especially not in cellular networks.  I.e. you must not use the dashboard when connected to other networks, because you do not own the public IP addresses associated with them.
You still can configure the OpenDNS FamilyShield addresses (see above) to block pornography, for example with the DNS changer app you used before.  I do not believe you can delete the app afterwards, else your DNS configuration may revert back.  These apps usually work with VPN technology, and if you delete the app, the VPN and related DNS configuration is gone too.
sdharminder889
How to use family shield on android phone to block pornography without using app?
Because anyone can change dns again on app to unblock pornography.
rotblitz
Level 6
Level 6
"How to use family shield on android phone to block pornography without using app?"
You follow the instructions at https://support.opendns.com/hc/en-us/articles/228009007 but use the OpenDNS FamilyShield addresses instead of the normal ones.
"Because anyone can change dns again on app to unblock pornography."
Yes, everyone having access to the device can change everything, no matter if with an app or not.  This is how Android works.  They didn't foresee restrictions like on computers or iOS devices.
You may check this: https://www.startpage.com/do/search?query=restrictions+on+android
sdharminder889
Can it not be use without on wi fi?
rotblitz
Level 6
Level 6
What?  What do you mean by "it", and what by "without"?
engg.
You can use OpenDns Home and login on this site from your mobile. Then there will show your current ip and you can add this to your list. It works in chrome normally but doesn't with incognito tab in chrome. While adding tick mark the option dynamic ip.
rotblitz
Level 6
Level 6
@engg.
These are not really good instructions.  You must not add IP addresses you do not own.
sdharminder889
I mean to say that I want to block porn content on my android device but without using any app and without using WiFi.
rotblitz
Level 6
Level 6
@sdharminder889
No, as far as I can see, you cannot configure DNS server addresses for cellular networks on Android.
sdharminder889
Can phone network apn (access point name) do any help to block porn on phone?
rotblitz
Level 6
Level 6
You need to contact the APN operator to see what they can do for you.
sdharminder889
Can you suggest me any other web content filtering from internet to block porn other than dns servers ,which can work on cellular networks? Because I can't use dns to block porn.
I want to delete my open dns account. But I forgot password and by mistake I have deleted my id. What to do?
