how can i block imgur
zeyadelkholy7
how can i block imgur.com
i used opendns and hosts to block it but nothing worked with me, plz help me
7 Replies 7
reham1
Please add the following domains to your Always Block list:
imgur.com
www.testelog.imgur.com
links.notifications.imgur.com
die.izt.i.imgur.com
samfreddy92.imgur.comsaman.imgur.com
i-imgur-com.cdn.ampproject.org
imgur.map.fastly.net
zeyadelkholy7
thx for your help. but it doesn't work . i need to block sharing links of imgur or imgur images link
reham1
It would appear that the site is pulling data from a site that you still need to block.
To check this and there are generally three methods you can use to figure out which domains are being referenced when loading a website.
1) Use the Web Developers Console option in Firefox (Tools -> Web Developer -> Web Console) and load the site on a computer that is not using OpenDNS, as it will list all of the domains referenced when a particular webpage loads.
2) Another method of figuring out which domains may be blocked on your network is by using Chrome Developer Tools.
Select the ⋮ menu at the top-right of your browser window, then select Tools -> Developer tools.
Right-click on any page element and select Inspect element.
On Windows and Linux, press Control - Shift - I keys to open Developer Tools
Control - Shift - J to open Developer Tools and bring focus to the Console.
Control - Shift - C to toggle Inspect Element mode.
On Mac, press ⌥⌘I (Command - Option - I) keys to open Developer Tools
⌥⌘J (Command - Option - J) to open Developer Tools and bring focus to the Console.
^⌘C (Control - Option - C) to toggle Inspect Element mode.
3) The site ***www.webpagetest.org*** also supplies this data and many people find this tool the easiest tool to use.
If you have any questions I would suggest that you create a support request so we can troubleshoot this problem thoroughly.
zeyadelkholy7
no the all images have the same domain www.imgur.com/theextention of the image
reham1
Did you run one of the three tests and find a domain or domains not in the list we provided?
zeyadelkholy7
yes. i done the three and found the only domain in imgur.com
zeyadelkholy7
this is the output of ping(the two domains is blocked on my blocking list):
ping imgur.com
PING imgur.com (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost (127.0.0.1): icmp_seq=1 ttl=64 time=0.016 ms
64 bytes from localhost (127.0.0.1): icmp_seq=2 ttl=64 time=0.040 ms
64 bytes from localhost (127.0.0.1): icmp_seq=3 ttl=64 time=0.036 ms
64 bytes from localhost (127.0.0.1): icmp_seq=4 ttl=64 time=0.032 ms
64 bytes from localhost (127.0.0.1): icmp_seq=5 ttl=64 time=0.052 ms
--- imgur.com ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4113ms
rtt min/avg/max/mdev = 0.016/0.035/0.052/0.011 ms
 zod   /  ping www.imgur.com
PING ipv4.imgur.map.fastly.net (146.112.61.104) 56(84) bytes of data.
64 bytes from hit-block.opendns.com (146.112.61.104): icmp_seq=1 ttl=56 time=75.9 ms
64 bytes from hit-block.opendns.com (146.112.61.104): icmp_seq=2 ttl=56 time=76.1 ms
64 bytes from hit-block.opendns.com (146.112.61.104): icmp_seq=3 ttl=56 time=75.8 ms
64 bytes from hit-block.opendns.com (146.112.61.104): icmp_seq=4 ttl=56 time=76.2 ms
64 bytes from hit-block.opendns.com (146.112.61.104): icmp_seq=5 ttl=56 time=76.9 ms
--- ipv4.imgur.map.fastly.net ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4004ms
rtt min/avg/max/mdev = 75.783/76.182/76.906/0.397 ms
