How to block fortnite
tofaneechokro
I have "Games" category block, however, fortnite game still able to connect and play.
rotblitz
Level 6
Level 6
In order for any dashboard settings taking effect, there must be these prerequisites:
  1. You must use OpenDNS.  Check at http://welcome.opendns.com/
  2. Your IP address must be correctly registered at https://dashboard.opendns.com/settings/
  3. You should flush your local caches once after the settings change.
In your case one of these conditions is apparently not met.
tofaneechokro
tried as per your instructions.. Fortnite not getting blocked
rotblitz
Level 6
Level 6
These have not been instructions, just reasons for why it doesn't work.  Instructions are provided in the knowledge base.
I need more information.  Copy & paste the complete plain text output of the following diagnostic commands to here:
nslookup -type=txt debug.opendns.com. 208.67.220.220
nslookup -type=txt which.opendns.com.
nslookup whoami.akamai.net.
nslookup fortnite.com.
nslookup www.epicgames.com.
