How to link a bypass code to a policy
hbackus
I am trying to create a bypass code for a URL but the Linked Policy has n/a in the column with triangle exclamation mark in it "ByPass Codes must be linked to a policy..".
How do you link a ByPass Code to a policy? The knowledge base article did not match my view of the Configurations screen.
6 Replies 6
rotblitz
Level 6
Level 6
Did you create a policy before which you could link a bypass code to?
hbackus
Thanks for the response.  I figured it out.
I am not familiar with the interface.
I wonder if it will change any with the Cisco rebranding. :-)
CervusCorp
I have to say who ever designed the UI for the site needs to consider how complex they made a simple task. Why not simply have a option under Linked Policy to "add"  or "associate"
Might I ask how you figured it out hbackus cause i am stuck in this same position...
hbackus
It's been awhile but I will see if I can remember all the steps.
Assuming you already have a policy and category or destination list you want to associate
Enter the policy and select the identity
support.opendns.com_hc_user_images_pSl5Wkj2NmBS1pwRqsKWBQ.jpegNext
Go into Policy Settings
Assuming you have the Category and Security setting you want
support.opendns.com_hc_user_images_YikCX8EePi36eW5M58Hsfg.jpegNext
At the Select Block Page Settings you can create a new bypass code at add code
support.opendns.com_hc_user_images_34bHAM3tQtmz1vfYqV83lw.jpegsupport.opendns.com_hc_user_images_zCSMQgfXL3sSaZA27MTVzw.jpegFrom the add code you can give it a name and check the category or destination you want
If I missed what you were trying to convey I apologize.
Hope this helps.
TheStranger
with the change in the GUI, how is this done now.
