04-08-2020 08:53 AM
I PURCHASED vip packege and no sites are blocked
04-08-2020 09:53 AM
What did you do to block sites? Purchasing OpenDNS Home VIP is not sufficient. You must explicitly configure what you want having blocked.
And, most important, you must use OpenDNS (VIP) to use the blocking features.
Are you using OpenDNS? Check at http://welcome.opendns.com/
04-12-2020 02:40 PM
I chose all porn sites you can enter and see but it is still not blocked
04-12-2020 03:17 PM
Are you using OpenDNS? http://welcome.opendns.com/
If yes, copy & paste the complete plain text output of the following diagnostic commands to here.
nslookup -type=txt debug.opendns.com.
nslookup whoami.akamai.net.
04-12-2020 04:24 PM
I click on the link you sent me and it says you dont use opendns although i am using it with my ip address you can enter and see
04-13-2020 03:56 AM
You must use OpenDNS in order to use it. What did you do to use it? You can also post the command outputs here, so that I may see what the problem is.
04-13-2020 08:18 AM
I purchased the vio package and I logged in and chose my ip address and chose moderate and applied it what should i do else to use opendns
04-13-2020 03:09 PM
The first step is to configure the OpenDNS resolver addresses on the router or on the end user device.
https://support.opendns.com/hc/en-us/categories/204012907-OpenDNS-Device-Configuration
04-21-2020 09:21 AM
Does it work now?
