open dns on my tp link router will not block porn
bernhean
oper dns on my tp link router will not block porn, I am not computer literate but i would appreciate some simple help. thank you
rotblitz
Level 6
Level 6
OpenDNS is not on your router, so it doesn't block porn there, but "in the cloud".
What message does http://welcome.opendns.com/ show up with?
jrahulsai
ya i too have same problem on tp link router its not filtering porn sites ever after setting high filtration level
rotblitz
Level 6
Level 6
Sad to hear.  And now?
You don't need to set to the "high" level, this may block too much.  It is sufficient to just check the Pornography category for blocking.
And again, what message does http://welcome.opendns.com/ show up with?
And is your IP address information correctly registered at https://dashboard.opendns.com/settings/ ?
