Openers not working
bobbybrowns
Confirmed IP address is correct but porn still getting thru.
What do I do to fix?
thanks!
9 Replies 9
rotblitz
Level 6
Level 6
Are you using OpenDNS? http://welcome.opendns.com/
bobbybrowns
Yes. Here is a screenshot of what link you provided.
However, the sites I want blocked are not blocked.
rotblitz
Level 6
Level 6
Visit https://dashboard.opendns.com/settings/ and ensure that the correct IP address is registered with your network.
bobbybrowns
My IP address is correct.
rotblitz
Level 6
Level 6
What did you do to block porn? Be aware that nothing is being blocked by default.
bobbybrowns
In Settings, select Custom, then checked pornography, Nudity, among others.
rotblitz
Level 6
Level 6
Well done!
Now copy & paste the complete plain text outputs of the following diagnostic commands to here.
nslookup -type=txt debug.opendns.com.
nslookup whoami.akamai.net.
nslookup www.exampleadultsite.com.
bobbybrowns
Well, i didnt have to copy and paste the outputs you provided. Not sure if you did anything on your side but it seems to be working as I had programmed it. I've tried searching with other devices and the questionable sites were blocked. I'll continue to try and get through the coming days and let you know if anything changes. So far so good.
rotblitz
Level 6
Level 6
Well, I did a lot on my side, but I doubt this would have any impact on you, because I’m just a user like you. LOL
