ā11-19-2017 07:23 AM
Open DNS blocks 'most' porn sites for me except pornhub. It blocks pichunter, persiankitty, freeones, redtube, etc. So it works but not well. Even if I blacklist pornhub individually it still is not blocked. Any ideas? Thanks.
ā11-19-2017 07:26 AM
Copy & paste the complete plain text output of the following diagnostic commands to here:
nslookup -type=txt debug.opendns.com.
nslookup www.pornhub.com.
ā11-19-2017 07:31 AM
Thank you. Here it is.
C:\Windows\system32>nslookup -type=txt debug.opendns.com.
Address: 192.168.1.1
Non-authoritative answer:
debug.opendns.com text =
"server m37.nyc"
"source 98.113.45.117:43720"
"actype 2"
"bundle 10587646"
"flags 20 0 8050 3B50400702000001001"
"originid 115699158"
C:\Windows\system32>nslookup www.pornhub.com.
Address: 146.112.61.104
Aliases: www.pornhub.com
ā11-19-2017 07:39 AM
It started blocking it now. I guess it just took longer than for other sites and I was impatient? Sorry and thanks for your help.
ā11-19-2017 07:47 AM
Yes, it's blocked. The address 146.112.61.104 shows that it is blocked by your individual domain block list.
The enemy is your local caches, resolver cache and browser cache. If you didn't flush them after the settings change, you were still served out of your local caches until their entries expire which can be hours, days or even weeks.
ā11-19-2017 07:49 AM
So you think this was cached?
/embarrassed
Thank you:)
ā11-19-2017 07:52 AM
Yes, your symptoms indicate that you have been served out of your caches.
See https://support.opendns.com/hc/en-us/articles/227988627
ā11-21-2017 09:09 AM
Try using the cmd command
ipconfig /flushdns
that will force your dns to cache again for new information
