problem with opendns family shield
mhdalshami
hi
i use OpenDNS family shield number
208.67.222.123
208.67.220.123
and its working good
but there is some adults site is still working and not blocked
how can i report this site to blocked ?
rotblitz
Level 6
Level 6
Not who, but where.
Here: https://community.opendns.com/domaintagging/submit/
You can also use OpenDNS Home, so that you can use the dashboard to block additional domains.
mhdalshami
I'm sorry i mean how not who..
thanks for your answer
But i have new question , can i use opendns home dashboard on android device ? and how "if i can" ?
rotblitz
Level 6
Level 6
If your Android device is connected via WLAN to your router where you have configured OpenDNS, then it uses OpenDNS, as any other device in your network.  OpenDNS is for networks you own, not for your devices in other networks, i.e. not for roaming devices.  On roaming devices you can still configure OpenDNS Family Shield, but cannot use your dashboard when away from your home network.
