Recent install - timing out and not internet connection
mikesesin
I recently added OpenDNS on my Motorola N450 router.  All seemed good until web pages started to become unresponsive, timed out or stated that there is no internet connection.  Network settings on all devices show that internet (either wired or wireless) are active and working.  I've had to reboot the router many times already and this resolves the issue, temporarily.
I have not set up any blocking as of yet and this is a new install so cache is fairly empty.
I've been reading through documents and prior questions on Community without luck so far.
If anyone has suggestions they would be appreciated.
rotblitz
Level 6
Level 6
This seems to be clearly a router glitch, so refer to your router supplier.
ac.clhs-tx.org
I am having the same issue on a Motorola MG7315. I'm very confident it's not a router glitch.
rotblitz
Level 6
Level 6
Not a router glitch?  Fine, then it would not work either if you configured OpenDNS on the computer, right?  Check it with this:
nslookup -type=txt debug.opendns.com. 208.67.220.220
