01-16-2021 08:21 PM
Respected Roblitz, i wanted to know about this below note
If you are forwarding requests to OpenDNS, domain blocking may not work properly if the domain's address is in your forwarder's cache
SO how do i know if i am forwarding requests to OpenDNS. By the way i use windows 10.
AGAIN another question is i have enabled the ipv6 settings in my wifi sections because if i close that my some applications dosen't work . Is there any role of ipv6 in preventing the web filtering and by the way i have also not specified any specific ipv6 DNS as i don't know the specific ipv6 address of OpenDNS.
01-17-2021 04:16 AM
You flush your local caches to purge domain names from it.
https://support.opendns.com/hc/en-us/articles/227988627-How-to-clear-the-DNS-Cache-
If you didn’t configure or disable IPv6, you likely do not use OpenDNS.
01-17-2021 04:27 AM
I don't know the IPv6 address of open dns and i have a dynamic IP which really changes very frequently ( although i use the client service for that) and my ip really changes very quick sometimes in a minute or even in seconds and again fluctuates back to original ip and again to something else. And like now as i was typing the client ip updater of opendns opened up and my ip adress chnages again this also really sucks.......... plzz help me with this also plzz explain in expanded form and yes with simple english plzz roblitz you are my guy...............plzzzzz
01-17-2021 04:57 AM
Configure your IPv6 settings with DNS server addresses from the following list:
::ffff:d043:dede ::ffff:d043:dcdc ::ffff:d043:dedc ::ffff:d043:dcde
IP addresses are assigned by ISPs. Only your ISP can help you with the fast changing IP address.
01-17-2021 08:47 AM
i figured everything but still opendns is unable to block some porn websites.
01-17-2021 09:21 AM
Ensure that the related domains are really categorized in the way you expect. If not, you can blacklist them one by one.
