System not doing anything. Not filtering any websites.
cito1
I followed all the instructions but the program does not seem to be doing anything.  It seemed very easy to set up but then nothing happens.  Nothing is filtered.
I see some people sharing stuff about running some commands.  Where do we run those?  Terminal?  Not sure what I'm missing.
Also, I'm using Utopia Fiber through X-mission in Utah.  My router is an Apple extreme base station.
static IP
5 Replies 5
rotblitz
Level 6
Level 6
Following up from https://support.opendns.com/hc/en-us/community/posts/360031831352/comments/360003143272
Yes, there's only one place where you can run commands on Mac OSX: the terminal window, of course.
nslookup -type=txt debug.opendns.com.
nslookup whoami.akamai.net.
ifconfig -a (Mac OSX)
cito1
Thank you for responding but I think I'm way behind.  Is there something I need to set up in my router for the OpenDNS to start working?
If so what?
I input all three commands you set above and the terminal spits out a bunch of stuff but I'm not sure I'm making much sense of it all.
rotblitz
Level 6
Level 6
As I said before, you need to copy & paste the complete plain text output of the diagnostic commands to here, so that I can review it to tell you what went wrong.  You do not need to question the sense of it.  I will do it for you.
And yes, you need to configure your router to use OpenDNS.  This is most important.
https://support.opendns.com/hc/en-us/articles/228006427
cito1
I just figured it out.  Nowhere during the signup and configuration process were there any instructions to change the DNS settings on my router.
I know this probably sounds totally elementary to you all but until I changed that nothing did anyting. I changed it and now things work.
It would be helpful if on the welcome e-mail it said:  change the DNS settings of your router to 208...... etc.
I know I probably should gotten the hint from the name of the product (openDNS) lol but I just didn't know to change that.
rotblitz
Level 6
Level 6
Weird how you could find a way to subscribe without hitting the step to configure OpenDNS on the router or on a device.  This essential step is where you stumble over everywhere.  If you receive a welcome e-mail, you are already far behind that first and most important step.
Whatever, glad to hear that it works for you now!
