05-15-2018 08:51 AM
I'm trying to block BBC on the OpenDNS Web Content Filtering. It appears not to work. I can't tell if it's because BBC use HTTPS or not, although I don't see how that would be related. I've used: Always Block: bbc.co.uk
05-15-2018 09:42 AM
In order for any dashboard settings taking effect, there must be these prerequisites:
In your case one of these conditions is apparently not met.
06-14-2019 11:16 AM
Had the same issue not certain why but I ended up having to block both bbc.co.uk and www.bbc.co.uk not sure if its something in thier DNS config or what but just blocking bbc.co.uk seems not to catch most things (despite the the claim you only need the root. Also you'll have to block bbc.com and www.bbc.com if you want to completely supress the extorsionists.
