Very slow connection speeds with OpenDNS
brentgm
After I set OpenDNS IP addresses on my router, my internet connection speeds tanked. I checked this out by undoing the OpenDNS set-up and the connection speeds bounced back. I don't know why this is happening and it looks to be something with the OpenDNS servers, themselves. But, if anyone has a fix, I would be happy if you would share it.
rotblitz
Level 6
Level 6
It could be that you are too far away from the next OpenDNS data center, in contrast to your ISP's DNS service.
brentgm
Thanks for your input! I actually discovered there was a combination effect between OpenDNS and an extension in my web browser that both serve a similar filtering function. Once I fixed this duplication issue, my connection speed came back. My apologies for neglecting to update my post. :P
