Other Security
Hi all, I used Gemini to help me write the following PowerShell script to pull custom events down from Secure Network Analytics, but when I run the script, I get the "The script connected and authenticated successfully, but the API returned 0 events....
rogoeke by Cisco Employee
  • 709 Views
  • 1 replies
I am trying to get information from FMC like NTP setting or logging setup etc. through api or cisco ansible collection.I know gui option but not able to map with api endpoint.  Below are good documentations but not handy to map gui with api end point...
Anyone know if there's an API within SNA or on the FC's themselves that will allow you to control the ignored IP list?  My issue is you can't create an audit comment within the FC's themselves as to WHY an IP is being ignored.
ryanmbess by Level 1
  • 726 Views
  • 0 replies
I'm trying to resolve alerts using our SOAR automation.  I'm using the api/v3/alerts/alert/<alert_id> endpoint and this PUT command body: { "resolved": true, "merit": 8, }  I'm receiving a status code 200 from Stealthwatch, so it seems like it accept...
m2oswald by Level 1
  • 3136 Views
  • 6 replies
Dear All, I was trying to create a script that will list out every authentication/authorization policy that has 0 hitcount, but it seems that the OpenAPI returns 0 hitcount for every policy set. ISE is 3.2 with P5If I am using ISE 3.1 it's working fi...
Hello. This is the first time I've tried to use Developer Hub community Support.  Please let me know if I need to take a different approach. Here is my problem. # I create a class and inside the class I only have integer variables. # I then create an...
dalthami by Cisco Employee
  • 5152 Views
  • 14 replies
Top Solution Authors
