09-09-2009 07:37 PM
my topology is like this.
cat6509<=>15454--15454<=>cat6509.
09-09-2009 08:14 PM
Okay, is that 15454 MSTP? If yes, you can use the ITU XENPAK or X2
DWDM XENPAK
DWDM X2
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6576/data_sheet_c78_489725.html
Minimum SW Requirement
09-09-2009 08:21 PM
on 15454 i use ONS-SE-G2F-SX SFP. u mean on cat 6509 i need to use XENPAK/DWDM X2 to connect to my 15454?
what happen if the 6509 use the normal SFP?
09-09-2009 08:27 PM
You initial question didn't specify anything, I thought you want to do DWDM OC192 between the 6500's.
Okay, I think you have the MUXPONDER card with the ONS-SE-G2F-SX optics. ONS-SE-G2F-SX is 850nm multimode. On the 6500, all you need is GLC-SX-MM if you are using the WS-X6724-SFP or WS-X6748-SFP line card.
jerry
09-09-2009 08:30 PM
yes.thats rite.on 6500 i use GLC-SX-MM. so do i need to configure something else to connect from Site A to Site B?
09-09-2009 08:32 PM
Are you looking for L2 or L3 configuration on the 6500?
jerry
09-09-2009 10:01 PM
it should be L3 config on 6500. is it i need to configure DWDM MTU size to match the 6500 MTU size?
09-10-2009 04:53 AM
MTU size on the 15454? The 15454 MUXPONDER is L1 to the C6500. The C6500 is only treating the MSTP as a piece of cable. The only thing you need to make sure is the SFP is configured for GE instead of FC.
jerry
09-10-2009 05:47 AM
What 15454 line card is the ONS-SE-G2F-SX SFP being plugged into?
