GLC-LX-SM-RGD Need Clarification
Eugene Dimitrov
Which fiber type is supported by this SFP?
In this sources, its says that MMF/SMF:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/installation/note/78_15160.html
But in this - that MMF only:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9703/data_sheet_c78-440930.html
P.S. I need to connect IE-3000-8TC (GLC-LX-SM-RGD) with (GLC-LH-SM) WS-C3750X-24T-S (C3KX-NM-1G)
P.S.S. sorry for my english
5 Replies 5
Marvin Rhoads
I read the last reference as saying single mode only:
GLC-LX-SM-RGD=
Gigabit Ethernet SFP, LC connector, LH (1Gps single mode) transceiver
You should be fine connecting the two devices you mention via singlemode fiber.
Ok, but I'm still don't understand.
Can I connect two IE-3000 with GLC-LX-SM-RGD via multimode? It appears that with IE-3000 this SFP can operate only with SMF fiber type.
Not unless you use a patch-conditioning-cable.
To add on to loelaohoo's response, the following document outlines the use of a mode conditioning patch cord when using the GLC-LX-SM-RGD SFP over multimode fibers (up to 550 meters).
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/product_bulletin_c25-530836.html
As per the SFP data sheets specs:
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6577/product_data_sheet0900aecd8033f885.html
Hope this clears things up.  Good luck!
Thanks for the reply!
I will check it
