Is there a GBIC to sfc patch cable?
compumend
I believe the currently installed fiber is GBIC, but the switch converter is mini-GBIC.  Is there a way to get these to work together?
Thanks.
chris-hart
I'm not really sure what you mean, GBIC is a type of interface convertor  and usually has SC Fibre connectors, the mini-GBIC you are referring to may be an SFP which is a smaller type of interface convertor and usually has LC Fibre connectors.
GBICs and SFPs will work together as long as they are the same type ie Single Mode or Multi Mode and you also need to make sure the TX and RX Optical Power levels are within the specified limits at both ends of the link.
On some switches the command "show inventory" may show the type of interface convertor installed.
SITE-A-CAT#show inventory
NAME: "SITE-A-CAT", DESCR: "Cisco Catalyst c2950 switch with 24 10/100 BaseTX ports and 2 GBIC (Gigabit Interface Converter) slots"
PID: WS-C2950G-24-EI   , VID: L0 , SN: FCZ1041Y0KJ
NAME: "GigabitEthernet0/1", DESCR: "longwave fiber gigabit ethernet port adapter"
PID: GBIC_LX           , VID: 30 30 30 30, SN: AGS094801V1
Or try the command "show interfaces gi/x/x/x capabilities" (where gix/x/x) is the interface number.
PE-CAT-A#show interfaces gi1/1/1 capabilities
GigabitEthernet1/1/1
  Model:                 ME-C3750-24TE
  Type:                  1000BaseLX SFP
  Speed:                 1000
  Duplex:                full
  Trunk encap. type:     802.1Q
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on,desired),tx-(none)
  Fast Start:            yes
  QoS scheduling:        rx-(not configurable on per port basis),tx-(4q2t)
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  SPAN:                  source/destination
  PortSecure:            yes
  Dot1x:                 yes
Hope this helps
Leo Laohoo
Sure.  All you need to do is find a cabled commonly called as an "SC to LC".  This cable comes in multiple flavours:  single-mode (SM), multi-mode (MM), straight cut, angle cut, strawberry, apple, etc.
NOTE:  I'm just kidding about the strawberry and apple bit.
