type of fiber patch cord
Eric Pinkerton
a 4900M is being moved 100 ft. from the core. currently connected via a 1 meter lc - lc 62.125MM patch cord using SFP-10G-LRM's. What type of fiber patch cord can be used to reconnected the 4900M to the core, 100ft away using the same sfp's?
5 Replies 5
Leo Laohoo
Single-mode fibre.
Thank you. I am working with HPE and they feel the MM will work on the 5412Rzl2 via a HPE 10GigFD.
So be it.
Make sure you keep a very close eye on the interface counters for any line errors.  This activity needs to be done regularly for the next 2 weeks.  I'd recommend doing this because you're using SFP+ optics.
In reading it looks like an OM3/4 fiber might be the compromise for both the Cisco and HPE?
fiberstorejames
Leo was right ! You should use the single-mode fiber for your network. because the SFP-10G-LRM transceiver that you use is the single-mode 10G SFP+ transceivers for long-hual applications.
