2851 Router
frederikd
Can 2 fibre optic cables with LX connectors be connected to a cisco 2851 router and if so what modules must be bought to connect the cables
lgijssel
Level 9
Level 9
In the 2851 you can use the HWIC-1GE-SFP but only one of these is supported.
Please check the datasheet:
http://www.cisco.com/en/US/products/ps5854/products_data_sheet0900aecd8016be8d.html
The type of module to use will depend on the type of fiber that you have i.e.single mode or multimode. The datasheet contains all supported SFP's.
regards,
Leo
