Broken plastic connector on line card - NCS2K-FSSMR-2-Lic
kbpreusse
So I am a NOC intern and one of our engineers asked me to install this line card in our porting room.  I thought I was being careful but managed to snap the plastic connector that helps hold the part in place.  Guess I didn't have it pushed all the way in and pushed a little too hard on the plastic piece.  I am wondering if its possible to get a replacement for it?  The line card still seems to be secure but could cause problems trying to take it in or out again in the future.  Thanks
Kevin
PS: I attached a picture of the plastic connector I am referring to.
marce1000
 - If it has a part number you can try ebay , seems to have a bar code it, scan or photograph it with a barcode scanning app on your phone, perhaps you will find more details , then again ebay may be source to launch a search for it.
 M.
Tom Randstrom
If you have any 15454 line cards that are non-functional, you might be able to harvest a tab from one of them and try to swap.
