Having an issue with TNCE cards coming up in a new M6 chassis that is being used as a subtended shelf. Is there any issue with the TNCE cards being used as opposed to using a TSC card?
You can use either or. TNC provides OSC where TSC does not. TSC is usually used for client shelves which hold Transponders. TNC is usually used for a line side shelf which hold the ROADM and amplifier cards. Thanks.
Learn, share, save
