01-10-2010 07:11 PM
Dear all,
I have brand new ONS 15305 SW version 3.0.5 and a CEC version 2.0.
I can connect to ONS via COM port and set the IP address and community string but I can not connect via management port.
The error pop up "Tried to connect to unsupport equipment"
Anyone knew the problem like this?
tanthanh85
Solved! Go to Solution.
02-12-2010 06:28 PM
You will see the error message when you try to connect to software version 3.0.5 with CEC version 2.0. Software version 3.0.5 requires you use CEC version 2.2.
Mike Dooley
Cisco Heartland TAC
02-12-2010 06:28 PM
Mike Dooley
Cisco Heartland TAC
