04-19-2024 12:40 AM
Is the Cisco SFP-10G-LRM module compatible with OS3 fiber?
04-19-2024 01:52 AM
- You probably refer to OM3 which supports up to 100M , that should work as per https://tmgmatrix.cisco.com/?tpid=76
max distance mentioned = 220M ,
M.
04-25-2024 09:08 AM
YES, Works on MMF and SMF 1310nm distance only 220m as RX sensitivity poor. OS3 Multimode fine.
