DATABASE BACKUP USING TL1 through an OSI link
fred_brownus
Is there a way to perform a database backup over OSI links through TL1 on the ONS 15454? The copy-rfile does not have an example with NSAP addresses or a FTTD format. I am running release 07.00-005L-19.20.
ebreniz
Level 6
Level 6
The Cisco ONS 15454 provides FTP database backup and restore download to ENEs when proxy/firewall is enabled. This feature allows you to provision a list of legal FTP hosts in CTC, that can be used with TL1 commands to perform database backup/restore or software download. And also TL1 users can then use the COPY-RFILE command to perform database backup/restore.
http://www.cisco.com/en/US/products/hw/optical/ps2006/products_technical_reference_chapter09186a0080894062.html#wp178886
Link looks dead, i'm looking to do the same thing. Able to upload software updates but getting "SWDL Incompatible With RFILE-PKG Aid" error message when trying to download backup's of the database.
Did you ever find out how to do this?
I get the below error when I try to copy software from node to server. I need help with correct syntax. Server is directly connected to node via tcc card. See below for the tl1 command I used and the error respectively. Thanks for your help in advance.
COPY-RFILE:HERNDON:RFILE-PKG:703::TYPE=SWDL,src=“FTP://CISCO15:otbu+1@192.168.5.54:21/ons15454.k9.R900.pkg”,
DEST=“FTP://kabiyesi:bishopp1@192.168.5.21:21/ons15454.k9.R900.pkg”,OVWRT=YES,FTTD=“FTTD_URL”;
HERNDON 2018-05-07 09:44:34
M 703 DENY
IITA
/* Input Invalid Target ID (sent by T-TD CISCO15) */
