10-29-2020 03:43 PM
does Cisco 10g OneX Converter Module (cvr-x2-sfp10g) support 10G BiDi SFP+ (10GBASE-BX10-U) ?
10-31-2020 11:56 AM
Enter the line card model number (that you will be installing the converter module within) into the Transceiver Compatibility Tool linked below to locate transceiver compatibility information.
10-31-2020 08:50 PM
The TMG matrix tool is silent with respect to the CVR-X2-SFP10G converters. It does tell us that the SFP-10G-BXU-I is compatible with the Catalyst 4900M in general.
https://tmgmatrix.cisco.com/?dr=10&npf=73
I think you're going to have to try in yourself or else open a TAC case to get a better answer than that.
