error message display when login CTC "Java.lang.NullPointerException"
kongmulake
Community Member
what will cause the message?Is it the wrong username and password ?
8 Replies 8
jreekers
Level 8
Level 8
Hi. It's not likely that it's a username/password problem. Can you post the full error here? It should look something like:
java.lang.NullPointerException
at cerent.cms.ui.EntityCellRenderer.getFormattedPortNumberFor(EntityCellRenderer.java:459)
at cerent.cms.ui.EntityCellRenderer.getPortString(EntityCellRenderer.java:288)
at cerent.cms.ui.shelf.OCNPortGraphic.getPortDescription(OCNPortGraphic.java:143)
at cerent.cms.ui.shelf.OCNPortGraphic.getTooltipText(OCNPortGraphic.java:158)
at cerent.cms.ui.shelf.OCNCard.getTooltipText(OCNCard.java:80)
at cerent.cms.ui.shelf.CardPanel.getToolTipText(CardPanel.java:136)
at javax.swing.ToolTipManager.mouseEntered(ToolTipManager.java:395)
at java.awt.AWTEventMulticaster.mouseEntered(AWTEventMulticaster.java:235)
at java.awt.Component.processMouseEvent(Component.java:3719)
at java.awt.Component.processEvent(Component.java:3539)
at java.awt.Container.processEvent(Container.java:1159)
at java.awt.Component.dispatchEventImpl(Component.java:2588)
at java.awt.Container.dispatchEventImpl(Container.java:1208)
at java.awt.Component.dispatchEvent(Component.java:2492)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:2446)
at java.awt.LightweightDispatcher.trackMouseEnterExit(Container.java:2313)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:2184)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:2120)
at java.awt.Container.dispatchEventImpl(Container.java:1195)
at java.awt.Window.dispatchEventImpl(Window.java:921)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:334)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:126)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:88)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:80)
-Joe
I attached the error message behind my post,Can you see the attachment?
I run the application under JRE1.4.2_04+IE6.0/IE7.0,and the list of files at the path ...\lib\security:
cacerts
java.security
local_policy
US_export_policy
javaws.policy
java.policy
and the content in "java.policy" is :
// Standard extensions get all permissions by default
grant codeBase "file:${java.home}/lib/ext/*" {
permission java.security.AllPermission;
// default permissions granted to all domains
grant {
// Allows any thread to stop itself using the java.lang.Thread.stop()
// method that takes no argument.
// Note that this permission is granted by default only to remain
// backwards compatible.
// It is strongly recommended that you either remove this permission
// from this policy file or further restrict it to code sources
// that you specify, because Thread.stop() is potentially unsafe.
// See "http://java.sun.com/notes" for more information.
permission java.lang.RuntimePermission "stopThread";
// allows anyone to listen on un-privileged ports
permission java.net.SocketPermission "localhost:1024-", "listen";
// "standard" properies that can be read by anyone
permission java.util.PropertyPermission "java.version", "read";
permission java.util.PropertyPermission "java.vendor", "read";
permission java.util.PropertyPermission "java.vendor.url", "read";
permission java.util.PropertyPermission "java.class.version", "read";
permission java.util.PropertyPermission "os.name", "read";
permission java.util.PropertyPermission "os.version", "read";
permission java.util.PropertyPermission "os.arch", "read";
permission java.util.PropertyPermission "file.separator", "read";
permission java.util.PropertyPermission "path.separator", "read";
permission java.util.PropertyPermission "line.separator", "read";
permission java.util.PropertyPermission "java.specification.version", "read";
permission java.util.PropertyPermission "java.specification.vendor", "read";
permission java.util.PropertyPermission "java.specification.name", "read";
permission java.util.PropertyPermission "java.vm.specification.version", "read";
permission java.util.PropertyPermission "java.vm.specification.vendor", "read";
permission java.util.PropertyPermission "java.vm.specification.name", "read";
permission java.util.PropertyPermission "java.vm.version", "read";
permission java.util.PropertyPermission "java.vm.vendor", "read";
permission java.util.PropertyPermission "java.vm.name", "read";
grant codeBase "http://*/fs/LAUNCHER.jar"
{permission java.security.AllPermission;};
"javaws.policy":
// @(#)javaws.policy 1.7 00/09/18
grant codeBase "file:${jnlpx.home}/javaws.jar" {
Hi.
Yes, I'm able to see the attachment, thanks.
Every time I've seen this error, it has been a jre compatibility issue with the version of CTC that is running. Can you please tell me what version of CTC you are running, and on what platform (Win2k, WinXP, etc.)?
-Joe
Sorry I don't known the version of CTC,I run the JRE on winXP,and I failed to connect the ONS by ftp . should I use a lower version of JRE to have a try?
Hi, CTC is the software that runs on TCC cards, main ONS software. The versions numbering will be something like ONS software 4.1-6.0, etc. If you can tell me what version you have, I can tell you what version of java you need. Without that, it would be a lot of guessing.
-Joe
thanks,jreekers,
It Should be 3.0 or 4.1.
Ok, that helps some.
Try JRE 1.3.1
-Joe
Not applicable
