GLC-SX-MMD Environmental Specs
What are the Humidity specs for the GLC-SX-MMD transceiver?
Marvin Rhoads
Cisco doesn't breask out that specification for the SFPs. However if you look at the switch it will be installed in, your can safely assume the compatible transceivers can also operate in that range.
For instance, the 2960-X hardware installation guide tells us the following:
Table 1 Environmental Specifications for All Catalyst 2960-X and 2960-XRSwitches
Environmental Ranges
Operating temperature
23 to 113°F (–5 to 45°C) up to 5,000 ft (1500 m)
23 to 104°F (–5 to 40°C) up to 10,000 ft (3000 m)
Storage temperature
–40 to 158°F (–40 to 70°C) up to 15,000 ft (4500 m)
Relative humidity
10 to 95% (noncondensing)
Storage altitude
Up to 15,000 ft (4500 m)
1 Minimum ambient temperature for cold start is 32°F (0°C)
Source: https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/hardware/installation/guide/b_c2960x_hig/b_c2960x_hig_appendix_0100.html#reference_3219E68F4B514783922B9D4A68082938
Even the ruggedized industrial use switches (like the IE 3010) designed for harsh environments have a similar range (5-95% in that case):
Table 13 Environmental and Physical Specifications
Operating temperature1
-40C to +74C
-40C to +70C (Vented Enclosure Operating)
-40C to +60C (Sealed Enclosure Operating)
-34C to +74C (100LFM or more Fan or Blower equipped Enclosure Operating)
-40C to +85C (Type Tested to +85C for 16 hours) 2
Storage temperature
–40 to 185°F (–40 to 85°C)
Relative humidity
5 to 95% (noncondensing)
Operating altitude
Up to 10,000 ft (3049 m)
Storage altitude
Up to 15,000 ft (4570 m)
Thermal spacing
1.75 in. (4.4 cm)
Operating shock
30 g at 11 ms
Source: https://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_ie3010/hardware/installation/guide/IE3010_hig/higspec.html#85391
