Java Security Issue, Certificate Exception, after installing CPO 9.6
Stephen King
Community Member
Hello all,
My gray hair is getting grayer by the minute.  Just finished installing CPO 9.6 on a RedHat Server.  Install completed fine, all the correct processes are running according to showctm.  Had the same issue installing another CPO a couple of years ago, but can't for the life of me remember how to fix the issue.  ( I will document, document, document this time, I swear).
This is the error I get when I try and log in as SysAdmin: "java.lang.RuntimeException: javax.net.ssl.SSLHandshakeException: java.security.cert.CertificateException: No subject alternative names present".
I have tried researching this and tried several "fixes" with no success.  I really need to get this turned up so I can decommission an old CTM server.
Thanks for the Help in advance..
Steve
0 Replies 0
