Need to understand LOG information for Cisco 15540
rlortiz
Anyone have an idea what could have caused the below log errors?:
Dec 31 06:06:04: %CPU_REDUN-5-PEER_EXITED_IOS: Peer CPU has exited IOS
Dec 31 06:06:04: %CPU_REDUN-5-STATUS_CHG: ACTIVE (sev 0), peer is NON-PARTICIPAN
T (sev 0)
T (sev 2)
Dec 31 06:06:04: %RF-3-COMMUNICATION: Communication with the peer CPU has been l
ost
Dec 31 06:06:04: %CPU_REDUN-3-PEER_COMM: Alarm: ASSERT, MINOR, CPU slot 6, Unpro
tected. Peer not responding,
Dec 31 06:06:04: %COUNTER_SYNC-3-TRANSMIT_ERROR: Unable to transmit message type
1 from Transparent10/2/0 action 1
Dec 31 06:06:04: %COUNTER_SYNC-3-STATUS: Performance stat sync failed on Trans
parent10/2/0
Dec 31 06:06:04: %COUNTER_SYNC-3-NO_BUFFER: No Memory to sync perf stats for Wav
e10/0
Dec 31 06:06:06: %LINK-3-UPDOWN: Interface Fastethernet-sby0, changed state to d
own
Dec 31 06:06:06: %LINK-3-UPDOWN: Interface Controller-peer0, changed state to do
wn
Dec 31 06:06:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fastethernet-sb
y0, changed state to down
Dec 31 06:06:07: %LINEPROTO-5-UPDOWN: Line protocol on Interface Controller-peer
Dec 31 06:06:32: %RF-3-COMMUNICATION: Communication with the peer CPU has been e
stablished
Dec 31 06:06:33: %CPU_REDUN-3-PEER_COMM: Alarm: CLEAR, MINOR, CPU slot 6, Unprot
Dec 31 06:06:34: %LINK-3-UPDOWN: Interface Controller-peer0, changed state to up
Dec 31 06:06:35: %LINEPROTO-5-UPDOWN: Line protocol on Interface Controller-peer
Dec 31 06:06:37: %CPU_REDUN-5-STARTUP_CONFIG_SYNCED: Startup config successfully
synced to standby
Dec 31 06:06:38: %CPU_REDUN-5-BASIC_CAPABILITY: Peer CPU hardware and software i
s fully compatible.
Dec 31 06:06:39: %CPU_REDUN-5-STATUS_CHG: ACTIVE (sev 0), peer is STANDBY (sev 2
Dec 31 06:06:39: %CPU_REDUN-5-STATUS_CHG: ACTIVE (sev 0), peer is STANDBY (sev 0
Dec 31 06:06:50: %LINK-3-UPDOWN: Interface Fastethernet-sby0, changed state to u
p
Dec 31 06:06:51: %LINEPROTO-5-UPDOWN: Line protocol on Interface Fastethernet-sb
y0, changed state to up
DWDM-TLC1-R1SW#
If you can get to this link the messages are explained there.
www.cisco.com/en/US/partner/products/hw/optical/ps2011/prod_error_message09186a00806065ca.html')">http://www.cisco.com/en/US/partner/products/hw/optical/ps2011/prod_error_message09186a00806065ca.html
It is the Cisco ONS 15540 ESPx System Alarms and Error Messages document. They are listed by the facility codes. In your example you look at what is there under CPU_REDUN.
You can also go down this path to get there:
www.cisco.com > (login) > Support > Troubleshoot > Optical Networking > Metro DWDM > Cisco ONS 15500 Series > error and System Messages
Then choose either:
1) Cisco ONS 15540 ESP System Alarms and Error Messages
OR
2) Cisco ONS 15540 ESPx System Alarms and Error Messages
Hope this helps.... Mike Dooley - Cisco Optical TAC
Michael Dooley
It appears the CPU in slot 7 rebooted. The slot 6 CPU (active) is reporting this from its point of view looking toward the standby CPU (its PEER):
PEER_EXITED
peer is NON-PARTICIPANT
Communication with the peer CPU has been lost
Int Fastethernet-sby0, changed state to down
and so on for the peer CPU to go down and come back up.
Thanks midooley that helps.
Then choose either:
OR
It definitely helps Mike..
Thanks again..
