Dears;When i tries to connect from CTM client to the CTM server the i receive the following error.(see the attached)
I am installing CTM 8.0 on a Solaris 10, Sparc 64 Sun Server/Workstation. I am having a problem installing the CTM, I installed Oracle 9i with no problems(that I know of) with patch 9.2.0.8. When I go to start the ctmsetup.sh it checks for the lat...
When creating a STS circuit would be a good practice to always create an STS-V circuit? It seems like that would give you added flexibility in the future if you want to increase the capacity. Is there a downside to creating an STS-v versus STS?
hello there. does anybody know if 12012 router can proceed about 1 Gb/s traffic peering BGP to 2 another AS? what card are suitable for 12012 router this 2 bgp connection? could it perform also to 10Gb/s for future bandwidth upstream upgrade? anyway ...
I want to drop 63E1 on my ONS 15454, I went through Cisco documentation and I found the following:Cisco 15454E-E1-42 (Cisco Cerent 15454E Interface Modules) 2qtyCisco 15454E-E1-120NP (Cisco Cerent 15454E Interface Modules) 2qty CISCO 15454E-E1-120...
Hi All, We are trying to install the optical multirate card (MRC 2.5Gig) on ONS 15454 and found the card comming up on standby state instead of active. The version running on the sonet box is 8.5.0 ...The MRC card port 1 is installed with the OC3 SF...
We have a new Cisco ONS 15454 software 7.2. When we turned up the box, it recognizes the OC3-8 card in Slot 14 (its in the inventory and shows up, but in a blue state), however its OOS. How can I provision it IN SERVICE? What is the TL1 command line?
Hi, I understand that for an 8-port 10Gb module (6509) ports 1,2,5 & 6 are the only performance 10 Gb ports (true 20Gb at full duplex) Does this mean I will not get the 10Gb throughput for another port, I'm debating whether or not it is worth moving ...
Hello there. what is the difference between them. i usually use the 1 Gb Ether SFP LX/LH. so when should i choose DWDM and CWDM? what is the benefit? tq all.
Hi,I hope this is the right place for my question.We need to setup an office with complete wireless network. I just want to know what devices are good if we want to limit the wireless to some particular range. I mean that we do not want our devices t...
Hi,We are planning to use ONS with EMC in order for replicating disk storage asynchronously to a remote location. Estimated bandwidth requirement is 240Mbps and I think that this can be possible by using 2xOC3 link from our telco provider. Is there a...
Kindly provide me the Speed of the following:STM-16STM-64E3
Hi All, We are experiencing high CPU utilization on one of our ML Card in the ONS 15454. The "IP Input" has relatively higher CPU utilization consumed irrespective of the proper fast/CEF switching enabled on the interfaces. We are trying to figure o...
I'm trying to bring up a POS interface with the provider. My side is a 7200. The interface is currently up/down. When the provider put a loop facing me. I could ping my interface with no errors. Any thoughts? What questions can I ask the provider to ...
Hallo.How can i get temperature of the node 15454 via TL1? I want to put this value to database.I was used utility getTemp.exe (WIN) for this before.getTemp.exe (Cisco ONS 15xxx NE Temperature Monitoring Utility 1.0.)
Subject | Author | Posted |
05-05-2024 05:19 AM | ||
03-27-2024 12:16 AM | ||
03-27-2024 12:09 AM | ||
09-10-2023 08:07 AM | ||
08-03-2023 03:20 AM |
