12-12-2015 06:22 AM
I have a Cisco router 2921/K9 connected to a PADTECH DWDM.
But the interface doesn't go up. I guess this is a negotiation issue, but I didn't find how to disable the auto-negotiation on the interface.
Below you have the outputs from the router.
interface GigabitEthernet0/1
no ip address
media-type sfp
end
RT01PGA-NOVO#sh int g0/1
GigabitEthernet0/1 is down, line protocol is down
Hardware is CN Gigabit Ethernet, address is 88f0.3185.fe11 (bia 88f0.3185.fe11)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full Duplex, 1Gbps, media type is LX
12-12-2015 09:02 AM
You indicated that the 2921's SFP is connected to the Padtech DWDM system. Is the SFP plugged into a Padtech 1G transponder card to convert it to a DWDM wavelength? The show interface indicates the SFP is a 1000BASE-LX, which is not compatible directly to a DWDM multiplexer without being converted to a DWDM compatible frequency.
Additional network information would be helpful.
SFP Transceiver Troubleshooting Guide
12-12-2015 09:25 AM
Thanks for answering.
Using this same SFP on a Cisco ASR the link goes up. The problem happens with Cisco 2921.
The topologies are:
2921 [sfp] ------------- DWDM -> Link down
ASR [sfp] ------------- DWDM -> Link up
12-12-2015 11:10 AM
Another guy had a similar problem (Cisco 3945 with SFP - full duplex possible?) but he solved his problem upgrading to 15.3 2T.
I tried that but it didn't work for me.
