10-18-2022 11:55 PM
We cannot see the transceiver detail as below.
Hardware
cisco Nexus9000 C9372TX chassis
Software
BIOS: version 07.17
NXOS: version 7.0(3)I1(2)
BIOS compile time: 09/10/2014
NXOS image file is: bootflash:///n9000-dk9.7.0.3.I1.2.bin
NXOS compile time: 5/16/2015 12:00:00 [05/17/2015 02:07:58]
Ethernet1/49
transceiver is present
type is 10Gbase-LR
name is CISCO-AVAGO
part number is SFCT-709SMZ-CS1
revision is G2.1
serial number is AVD1938T0WJ
nominal bitrate is 10300 MBit/sec
Link length supported for 9/125um fiber is 10 km
cisco id is 3
cisco extended id number is 4
Ethernet1/50
type is 10Gbase-LR
name is CISCO-AVAGO
revision is G2.1
serial number is AVD1938T0WP
cisco id is 3
Ethernet1/51
type is QSFP-40G-SR-BD
name is CISCO-AVAGO
part number is AFBR-79EBPZ-CS2
revision is 01
serial number is AVM1923U20Q
nominal bitrate is 20600 MBit/sec per channel
Link length supported for 50/125um OM3 fiber is 100 m
cisco id is 13
cisco extended id number is 220
Ethernet1/52
name is CISCO-AVAGO
revision is 01
serial number is AVM1923U20X
cisco id is 13
Ethernet1/53
name is CISCO-AVAGO
revision is 01
serial number is AVM1923U210
cisco id is 13
Ethernet1/54
name is CISCO-AVAGO
revision is 01
serial number is AVM1923U20Z
cisco id is 13
Port Name Status Vlan Duplex Speed Type
Eth1/49 Connected to connected trunk full 10G 10Gbase-LR
Eth1/50 Connected to connected trunk full 10G 10Gbase-LR
Eth1/51 -- speedGrpC 1 auto auto QSFP-40G-SR-BD
Eth1/52 -- speedGrpC 1 auto auto QSFP-40G-SR-BD
Eth1/53 -- speedGrpC 1 auto auto QSFP-40G-SR-BD
Eth1/54 -- speedGrpC 1 auto auto QSFP-40G-SR-BD
Ethernet1/49
type is 10Gbase-LR
name is CISCO-AVAGO
revision is G2.1
cisco id is 3
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature N/A N/A N/A N/A N/A
Voltage N/A N/A N/A N/A N/A
Current N/A N/A N/A N/A N/A
Tx Power N/A N/A N/A N/A N/A
Rx Power N/A N/A N/A N/A N/A
Transmit Fault Count = 0
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
Ethernet1/50
type is 10Gbase-LR
name is CISCO-AVAGO
revision is G2.1
cisco id is 3
Ethernet1/51
name is CISCO-AVAGO
revision is 01
cisco id is 13
DOM is not supported
Ethernet1/52
name is CISCO-AVAGO
revision is 01
cisco id is 13
Ethernet1/53
name is CISCO-AVAGO
revision is 01
cisco id is 13
Ethernet1/54
name is CISCO-AVAGO
revision is 01
cisco id is 13
Thank you,
