12-23-2014 07:46 AM
In one of my customer's newly installaed setup I am getting below message in one of the c3750x stack switch.
Mar 31 06:02:54.875: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/1/1: Rx power low alarm; Operating value: -26.8 dBm, Threshold value: -21.0 dBm
Mar 31 06:02:55.135: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/1/2: Rx power low alarm; Operating value: -26.0 dBm, Threshold value: -21.0 dBm
Mar 31 06:02:57.392: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/1: Rx power low alarm; Operating value: -27.4 dBm, Threshold value: -21.0 dBm.
Mar 31 06:02:57.669: %SFF8472-5-THRESHOLD_VIOLATION: Gi2/1/2: Rx power low alarm; Operating value: -26.6 dBm, Threshold value: -21.0 dBm.
Pls. have a look and suggest me on how to resolve the issue.
Thanks in advace.
12-23-2014 12:35 PM
What SFP modules are being used.
Start by cleaning the fibre optic patch cable ends.
12-23-2014 10:38 PM
Hi Leo,
SFP modules used are
12-24-2014 04:47 AM
Pradip,
If you aren't using those ports, then putting them in disable state, with "shutdown", should cause the alarm to stop popping up.
12-24-2014 05:12 AM
12-24-2014 05:41 AM
Pradip,
This isn't really a problem, if you don't have anything connected. It's just an error telling you that the fiber optic port isn't receiving much of a signal. If you have a fiber connected and you get this error, that means an insufficient amount of light is being received on that port. Insufficient rx signal can mean you have a broken fiber, your transmit port on the the other end isn't working correctly, or many other root causes.
In your case you had nothing connected, and since the ports are enabled they expect to receive signal, but receive nothing, causing your error.
So nothing is really wrong with your switches.
12-24-2014 05:47 AM
Thanks for yoursupport.
08-03-2015 10:12 AM
This discussion has been reposted from Additional Communities to the Optical Networking community.
