problem with link aggreagation with copper to fiber media converter in betw
fb_webuser
Level 6
Level 6
when normal link aggregation(without media converter in between) it works fine but when a media converter is in between it goes down..
Posted by WebUser Xyronne Encinares
Craig_Baum_2
It probably means that your media converters are not passing the electrical link state messages through .
There are numerous other reports on forums with similar problems..
https://supportforums.cisco.com/thread/2116802
Not sure what the answer is but you could prove this by debug the lacp packets on the interface without and then with to see if update packets are missing..
Hopefully someone else can help short of buying new cards/gbics.
