Problem with X2-LR trancievers on Catalyst 4500 IOS Version 15.0(2)SG9
We have a Supervisor V-10GE with two X2 trancievers, so the problem is no link when I loop the trancievers. Help me plz.
sh int trans
             Optical   Optical
           Temperature  Voltage  Tx Power  Rx Power
Port       (Celsius)    (Volts)  (dBm)     (dBm)
Te1/1        34.0       0.00      -2.4      -6.2
Te1/2        31.0       0.00      -2.0      -5.9
sh log
Feb 4 08:38:46.568: Port Te1/2: X2 inserted: vendor: CISCO-EXCELIGHT, p/n: SDX4101FL-C1-M, s/n: ECL1016015D , DOM capable, the hole supports monitoring
Feb 4 08:38:46.860: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=2: Transceiver has been inserted
Feb 4 08:38:53.397: Port Te1/1: X2 inserted: vendor: CISCO-EXCELIGHT, p/n: SDX4101FL-C1-M, s/n: ECL1008003H , DOM capable, the hole supports monitoring
Feb 4 08:38:53.861: %C4K_IOSINTF-5-TRANSCEIVERINSERTED: Slot=1 Port=1: Transceiver has been inserted
sh ru
Port      Name               Status       Vlan       Duplex  Speed Type
Te1/1                        notconnect   555          full    10G 10GBase-LR
Te1/2                        notconnect   1            full    10G 10GBase-LR
sh int status
Tom Randstrom
Are you looping the transceiver back locally (near the device) or at the far end (at the other end of the link)?  The reason I ask is that the receive levels are showing attenuation.  Are you using a singlemode fiber jumper?
So I make loop localy using single mode patchcord.
