QDD-400G-ZR-S QDD-400G-ZRP-S DCO Coherent
tim20110612
Hello everyone,
Cisco N9K-C93600CD-GX, NXOS: version 10.5(1).
Does using the third-party QSFPDD 400G ZR/ZR+ on this device require an additional license?
Thank you very much for your help!
N9K-93600# sh int e 1/29 transceiver details
Ethernet1/29
transceiver is present
type is QSFP-DD-400G-ZRP-S
name is
part number is
revision is D1
serial number is
nominal bitrate is 425000 MBit/sec per channel
cisco id is 24
cisco extended id number is 51
firmware version is 1.60
Link length SMF is 12 km
Nominal transmitter wavelength is 1547.70 nm
Wavelength tolerance is 0.015 nm
host lane count is 8
media lane count is 1
max module temperature is 70 deg C
min module temperature is 0 deg C
min operational voltage is 3.14 V
vendor OUI is 0x44d5a5
date code is 240927
power class is 8 (>14 W maximum)
max power is 19.50 W
near-end lanes used none
far-end lane code for 8 lanes Undefined
media interface is unknown value 0x10
Advertising code is Optical Interfaces: SMF
Host electrical interface code is 400GAUI-8 C2M (Annex 120E)
Lane Number:1 Network Lane
Current Alarms Warnings
Measurement High Low High Low
Temperature N/A N/A N/A N/A N/A
Voltage N/A N/A N/A N/A N/A
Current N/A N/A N/A N/A N/A
Tx Power N/A N/A N/A N/A N/A
Rx Power N/A N/A N/A N/A N/A
Transmit Fault Count = 0
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
*** This QSFP support partial diagnostic data! ***
marce1000
       - It doesn't ,
 M.
marce1000
       - It doesn't ,
 M.
Hello Marce,
Thank you very much for the information!
