SFP-10G-LR compatible cabels
hapohell1
hello,
i would appreciate some help on the following manner:
which fiber optic cable it compatible with the SFP-10G-LR module. i understand that a single mode, LC-LC suppose to be ok.
is that cable suitable: http://approvedoptics.com/cisco-15216-lc-lc-20/ ?
would a multimode OM3 cable will fit?
Marvin Rhoads
The SFP-10G-LR requires a single mode cable. The one you linked is fine.
A multimode OM3 cable will not work with the LR module. It would work only with the SR series of 10 Gbps transceivers.
