SFP 20km
AndreasKvist
Which is the recommended SFP if the request is
Cisco SFP+ 10G 1310nm 20km LR
Using the TMG tool i do not get any findings on 20km reach
Google gives me a lot of 3rd party direct findings.
Please advice.
Br
Andreas
Mark Malone
Whats the switch or router , this link below will tell you , put in your device it will give you all options for that hardware, all sfp types and supported ranges , you will need SMF SFP anyway at that distance
https://tmgmatrix.cisco.com/home
Zaaf Aba
Previously I came across a requirement where we had to connect two data centres using dark fibre @10gbps. Our switch model had compatible LR4 SFP available supporting to 40km. We also explored ER4 sfp for 40gbps@40km but those were expensive and couldn't justify using them just for the sake of future proofing.
Most likely you have to use sfp supporting 10gbps@40km
FYI, most common long distance (=>1km) sfp modules available in descending order across different platforms are listed below , with few also being end of sale.
Distance --- number of SFP available
10km --- 4675
40km --- 2573
80km --- 2004
70km --- 1031
2km --- 925
1km --- 910
25km --- 58
1km(OM4)--- 26
15km --- 25
10km --- 8
20km --- 4
