Where can I purchase a T1 patch panel for cable 15310-LFH-AMP-10?
zhiqiang.fang
We would like to installate a 15310-CL, and the 21 T1 ports need to be connected to DDF by cable "15310-LFH-AMP-10" with 2 SCSI connectors at one end. Now we can not find any company selling the T1 patch panel suitably for this Cisco cable, with at least 21 RJ48 and 2 SCSI.
It will be appreciate if any one tell us where to purchase this kind of panel.
Tom Randstrom
Would something like the following wire-wrap to RJ48 patch panel from Telect (Part Number 097-0032-0001) work for your application:
http://www.telect.com/www/Products/LearnMore2.aspx?CatalogId=Telect+Products&ProductId=Clearance_Copper&VariantId=097-0032-0001
Hopefully this works for your application.
Tom
Tom Randstrom
Tom
Thanks a lot.
Following your suggestion, I find another customer interface panel with 2X64 pin female connectors, which is suitable for cisco cable, and I mistaked it for SCSI.
The panel part Number is 097-0128-0007:
http://www.telect.com/www/Products/LearnMore.aspx?CatalogId=Telect+Products&ProductId=T1%2fDS1+Customer+Interface+Panels_pid0201&VariantId=097-0128-0007
While we need to ensure with Telect that it could work.
Thanks again!
BR
Zhiqiang
