06-05-2016 10:29 PM
I have an old switch WS-C4503-E (Sup 6) having the X2 10G module slot and another site is new 4503-E (Sup 7) having the SFP 10G slots,
now i want to communicate between this two switches using X2-10G-LR and SFP-10G-LR, so is it possible or not ?
Please suggest.
Debabrata
06-05-2016 10:48 PM
Yes it is possible. What is the distance between the two?
06-05-2016 11:31 PM
Maximum distance is 7km and minimum 20mtrs.
Debabrata
06-06-2016 06:29 PM
As Leo Laohoo indicated, you can interconnect your two switches with a X2-10G-LR on one end and a SFP-10G-LR on the other. These optical transceivers are qualified to 10km using singlemode fiber. No attenuator is required for the shorter distance.
