X2 transceiver - CISCO-SUMITOMO - syslog message - SFF8472-5-THRESHOLD_VIOLATION
Manuel Muetsch
I have a problem with X2 transceivers from "CISCO-SUMITOMO".
The WS-C3560E-12D-S Catalyst Switch generates the following syslog message due to the fact that it cannot read out the operating voltage value:
%SFF8472-5-THRESHOLD_VIOLATION: Te0/8: Voltage low alarm; Operating value: 0.00 V, Threshold value: 3.07 V.
The switch is running the follwing image:
c3560e-universalk9-mz.150-1.SE
Unfortunately, due to the fact that the global command "logging discriminator" is not supported in IOS version 15.0(1+2)SE it is not possible to filter the message.
After a lot of research and reading I can say that this is not a known open caveat:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/15.0_2_se/release/notes/OL25302.html#wp1025298
Do you have any suggestions how I can avoid those messages?
Replacement is not an alternative for me!
Thanks in advance.
Manuel
Further down you will see the characteristics of the X2 transceivers.
LWL-Switch# show int te 0/1 transceiver
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                 Optical   Optical
           Temperature  Voltage  Tx Power  Rx Power
Port       (Celsius)    (Volts)  (dBm)     (dBm)
Te0/1        28.6       0.00      -2.1      -1.7
LWL-Switch# show int te 0/8 transceiver
                                 Optical   Optical
Te0/8        30.5       0.00      -2.5      -2.3
LWL-Switch#show idprom int te 0/1
        SEEPROM contents (hex) size 256:
          0x00: 1E 01 00 01 00 0B 77 A7 01 00 00 02 01 01 28 48
          0x10: 01 02 00 00 00 00 00 00 00 00 00 03 E8 20 00 01
          0x20: FF B8 00 00 00 00 00 00 00 00 00 00 C0 9B E0 00
          0x30: 03 E8 00 43 49 53 43 4F 2D 53 55 4D 49 54 4F 4D
          0x40: 4F 20 20 53 44 58 34 31 30 30 4C 52 2D 43 31 2D
          0x50: 4D 20 20 42 20 53 50 43 31 34 34 35 30 35 34 30
          0x60: 20 20 20 20 20 32 30 31 30 31 31 30 33 30 32 00
          0x70: 01 02 04 C7 01 00 EA 58 32 2D 31 30 47 42 2D 4C
          0x80: 52 20 20 20 20 20 20 20 56 30 34 20 53 50 43 31
          0x90: 34 34 35 30 35 34 30 31 30 2D 32 30 33 36 2D 30
          0xA0: 34 20 20 41 30 20 20 00 00 00 00 00 00 00 00 00
          0xB0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0xC0: 84 01 8A 33 1F 88 9F 18 99 15 90 01 13 43 04 00
          0xD0: 00 00 00 00 00 00 00 00 00 00 00 0B AF 2F 9F CD
          0xE0: 64 1D 5E 58 B5 70 FB 95 BB 1E 26 41 00 00 00 00
          0xF0: 00 00 00 00 00 5B 62 4B 45 18 10 11 E0 00 D9 20
X2 Serial EEPROM Contents:
Non-Volatile Register (NVR) Fields
X2 Version                           :0x1E = MSA Version 0x1E
NVR Size in bytes                    :0x100
Number of bytes used                 :0x100
Basic Field Address                  :0xB
Customer Field Address               :0x77
Vendor Field Address                 :0xA7
Extended Vendor Field Address        :0x100
Reserved                             :0x0
Transceiver type                     :0x2 =X2
Optical connector type               :0x1 =SC
Bit encoding                         :0x1 =NRZ
Normal BitRate in multiple of 1M b/s :0x2848
Protocol Type                        :0x1 =10GbE
Standards Compliance Codes :
10GbE Code Byte 0                    :0x2 =10GBASE-LR
10GbE Code Byte 1                    :0x0
SONET/SDH Code Byte 0                :0x0
SONET/SDH Code Byte 1                :0x0
SONET/SDH Code Byte 2                :0x0
SONET/SDH Code Byte 3                :0x0
10GFC Code Byte 0                    :0x0
10GFC Code Byte 1                    :0x0
10GFC Code Byte 2                    :0x0
10GFC Code Byte 3                    :0x0
Transmission range in 10m            :0x3E8
Fibre Type :
Fibre Type Byte 0                    :0x20 =SM, Generic
Fibre Type Byte 1                    :0x0 =Unspecified
Centre Optical Wavelength in 0.01nm steps - Channel 0 :0x1 0xFF 0xB8
Centre Optical Wavelength in 0.01nm steps - Channel 1 :0x0 0x0 0x0
Centre Optical Wavelength in 0.01nm steps - Channel 2 :0x0 0x0 0x0
Centre Optical Wavelength in 0.01nm steps - Channel 3 :0x0 0x0 0x0
Package Identifier OUI  :0xC09BE0
Transceiver Vendor OUI  :0x3E800
Transceiver vendor name :CISCO-SUMITOMO
Part number provided by transceiver vendor       :SDX4100LR-C1-M
Revision level of part number provided by vendor :B
Vendor serial number           :SPC14450540
Vendor manufacturing date code :2010110302
Current Reference :
5V Stressed Environment Reference 100 percent=1A   :0x0
3.3V Stressed Environment Reference 100 percent=2A :0x1
APS Stressed Environment Reference 100 percent=2A  :0x2
Normal APS Voltage :0x4
Digital Optical Monitoring Capability Byte  :0xC7
Digital Optical Monitoring                  :Implemented
Low Power Start-up(LPS) Mode Capability Bit :0x1
Reserved             :0x0
Basic Field Checksum :0xEA
Customer Writable Area :
  0x00: 58 32 2D 31 30 47 42 2D 4C 52 20 20 20 20 20 20
  0x10: 20 56 30 34 20 53 50 43 31 34 34 35 30 35 34 30
  0x20: 31 30 2D 32 30 33 36 2D 30 34 20 20 41 30 20 20
Vendor Specific :
  0x00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x10: 00 00 00 00 00 00 00 00 00 84 01 8A 33 1F 88 9F
  0x20: 18 99 15 90 01 13 43 04 00 00 00 00 00 00 00 00
  0x30: 00 00 00 00 0B AF 2F 9F CD 64 1D 5E 58 B5 70 FB
  0x40: 95 BB 1E 26 41 00 00 00 00 00 00 00 00 00 5B 62
  0x50: 4B 45 18 10 11 E0 00 D9 20
Device : X2 PMA PMD
0000: 2040        :  0010 0000 0100 0000
0001: 0006        :  0000 0000 0000 0110
0002: 0003        :  0000 0000 0000 0011
0003: E800        :  1110 1000 0000 0000
0004: 0001        :  0000 0000 0000 0001
0005: 001E        :  0000 0000 0001 1110
0006: 0000        :  0000 0000 0000 0000
0007: 0006        :  0000 0000 0000 0110
0008: B145        :  1011 0001 0100 0101
0009: 0000        :  0000 0000 0000 0000
Device : X2 PCS
0007: 0000        :  0000 0000 0000 0000
0008: 8005        :  1000 0000 0000 0101
Device : X2 WIS
0001: 0002        :  0000 0000 0000 0010
0008: 8003        :  1000 0000 0000 0011
Device : X2 XGXS
0008: 8000        :  1000 0000 0000 0000
Device : 10G Phy
0001: 0004        :  0000 0000 0000 0100
0002: 0000        :  0000 0000 0000 0000
0003: 0000        :  0000 0000 0000 0000
0005: 0020        :  0000 0000 0010 0000
FC-FF-FF, 3F-0F, 01-02
LWL-Switch#show idprom int te 0/8
          0x10: 01 00 00 00 00 00 00 00 00 00 00 00 16 01 00 01
          0x40: 4F 20 20 53 44 58 34 31 30 32 4C 4D 2D 43 35 2D
          0x50: 4D 20 20 41 20 45 43 4C 31 34 35 33 30 30 44 4C
          0x60: 20 20 20 20 20 32 30 31 31 30 31 31 34 36 36 00
          0x70: 02 08 02 C7 01 00 19 58 32 2D 31 30 47 42 2D 4C
          0x80: 52 4D 20 20 20 20 20 20 56 30 33 20 45 43 4C 31
          0x90: 34 35 33 30 30 44 4C 31 30 2D 32 33 36 38 2D 30
          0xA0: 33 20 20 41 30 20 20 08 00 00 00 00 80 FF 68 88
          0xB0: 00 E0 00 00 00 00 84 44 00 96 00 00 00 00 00 00
          0xC0: 00 38 00 60 B8 06 A7 80 F0 4F 00 00 00 00 00 00
          0xD0: 00 00 00 00 00 00 00 00 00 02 00 0B F8 20 96 FA
          0xE0: 8B F8 51 66 0C 5B 5B 06 DF C4 5A AA 00 00 00 00
          0xF0: 00 00 00 00 00 B7 31 B6 BF 15 C9 0C 8A 01 3C 20
Reserved                             :0x0
10GbE Code Byte 0                    :0x0 =10GBase-LRM
Transmission range in 10m            :0x16
Fibre Type :
Fibre Type Byte 0                    :0x1 =MM, Generic
Part number provided by transceiver vendor       :SDX4102LM-C5-M
Revision level of part number provided by vendor :A
Vendor serial number           :ECL145300DL
Vendor manufacturing date code :2011011466
Current Reference :
3.3V Stressed Environment Reference 100 percent=2A :0x2
APS Stressed Environment Reference 100 percent=2A  :0x8
Normal APS Voltage :0x2
Reserved             :0x0
Basic Field Checksum :0x19
  0x00: 58 32 2D 31 30 47 42 2D 4C 52 4D 20 20 20 20 20
  0x10: 20 56 30 33 20 45 43 4C 31 34 35 33 30 30 44 4C
  0x20: 31 30 2D 32 33 36 38 2D 30 33 20 20 41 30 20 20
Vendor Specific :
  0x00: 08 00 00 00 00 80 FF 68 88 00 E0 00 00 00 00 84
  0x10: 44 00 96 00 00 00 00 00 00 00 38 00 60 B8 06 A7
  0x20: 80 F0 4F 00 00 00 00 00 00 00 00 00 00 00 00 00
  0x30: 00 00 02 00 0B F8 20 96 FA 8B F8 51 66 0C 5B 5B
  0x40: 06 DF C4 5A AA 00 00 00 00 00 00 00 00 00 B7 31
  0x50: B6 BF 15 C9 0C 8A 01 3C 20
Device : X2 PMA PMD
0002: 0020        :  0000 0000 0010 0000
0003: 6035        :  0110 0000 0011 0101
0005: 001A        :  0000 0000 0001 1010
0007: 0008        :  0000 0000 0000 1000
0008: B301        :  1011 0011 0000 0001
Device : X2 PCS
0008: 8001        :  1000 0000 0000 0001
Device : X2 XGXS
0002: 0143        :  0000 0001 0100 0011
0003: BDC1        :  1011 1101 1100 0001
0005: 0010        :  0000 0000 0001 0000
Device : 10G Phy
By the following X2 transceivers the operating voltage value cannot be read out, too, but there will be no syslog message generated:
CISCO-OPNEXT,INC
CISCO-FINISAR
CISCO-AVAGO
Manuel Muetsch
The Event Syslog Manager is working in IOS version 15.0(1+2)SE so I'am now using the following Tcl script to filter the syslog message.
if [string match "*SFF8472-5*" $::orig_msg] {
    return ""
} else {
    return $::orig_msg
