CISCO REST API for Call Control
ahmadjalal2270
I am a PHP developer and need to integrate CISCO cloud system with our third party APP. I need to log all incoming and outgoing calls information in our third party APP. I have not found any stuff or helping material related to the call control API on internet. Can you please let me know it's possible or not through API?
If its possible then please send me some helping material or API documentation URL, I will be very thankful to you for your help.
Thanks & Regards,
LoisSwartz63
Good question: Try to use TBE to get Cisco packet tracer.
Culver's Guest Satisfaction Survey
Sergiu.Daniluk
What does Cisco Cloud System mean? What product are you referring to?
Joseph84174
The REST API (or RESTful API) is one of the Northbound APIs supported by NSO, and the client can operate NSO using HTTP(S). The REST API itself is used not only in NSO but also in other products, and because it is easy to call from Javascript, it is often used in web portals and so on.  Huddle Hyvee Login
