Cloud Management for switches
michael.nabil10
I need to know more about the new feature of switches management through cloud
balaji.bandi
What Model of switches? if you looking Cat 9K Switch, now you can manage using Meraki Dashboard. ( that means you can manage Meraki devices and Cat 9K switches - check the IOS XE requirement)
If you are looking at DNAC - that is for SD-Access.
https://www.cisco.com/c/m/en_uk/solutions/enterprise-networks/nb-06-cloud-managed-catalyst-infograph.html
BB
neskemiquel
@michael.nabil10 wrote: Dashboard Anywhere
With cloud management, thousands of switch ports can be configured and monitored instantly over the web. Without needing a physical connection between switches, you can remotely configure them for access devices, assign voice VLANs, control PoE, and more, with just a few simple clicks and without on-site IT.
