3rd party transceiver in Cisco Nexus 5500
frede_frede
This is the output of a 3rd party transceiver:
Ethernet1/26
    transceiver is present
    type is 10Gbase-(unknown)
    name is Amphenol
    part number is 530-4451-01-
    revision is
    serial number is APF124900235KA
    nominal bitrate is 10300 MBit/sec
    Link length supported for copper is 3 m
    cisco id is --
    cisco extended id number is 4
This can bring problems, any special configuration for this cases?
This is a cable QSFP to 4xSFP+, the SFP+ is on the Nexus side.
Steve Fuller
Level 9
Level 9
There should be no special configuration needed as since NX-OS 4.1(3)N2(1) the Nexus will attempt to bring up the port even with non Cisco transceivers installed. The process is as follows:
If attached interconnect (transceiver) is a twinax cable, then verify transceiver SPROM to match Cisco magic code. If the check succeeds then bring up the interface else check whether the Vendor Part Number (PN) has been certified. If the Vendor PN is certified bring up the interface else print a warning message stating that non-Cisco transceiver is attached (shown below) and try to bring up the port.
2009 Oct 9 01:46:42 switch %ETHPORT-3-IF_NON-CISCO_TRANSCEIVER: Non-Cisco transceiver on interface Ethernet1/18 is detected.
The one are you might run into an issue is support, as stated in the Twinax Cables Certification Matrix for Cisco Nexus 2000 and Nexus 5000 Series Switches Data Sheet:
If a twinax cable that is not part of the compatibility matrix is connected into a system, Cisco TAC will still debug the problem provided the customer has valid support contract on the switches. However TAC may ask the customer to replace with Cisco qualified cables if there is a situation that points to cables possibly being faulty or the customer will be redirected to the cable provider for support
Steve Fuller
Level 9
Level 9
Thanks Steve
I didn't have any problems connecting the cables.
Fred
