02-25-2011 04:27 AM - edited 03-01-2019 06:54 AM
I setup an ace module in bridge mode as follows:
mfsc(vla80) > (vla80)outside fwsm, fwsm inside(vla40) > (vla40)ace-clientside, aceserverside(vla41)
and the servers have the fwsm svi(vla40) as their gateway. But, the ace is not loadbalancing.
The config script is attached. Is their anything I am missing?
03-21-2011 06:42 PM
Hi tolulopebalogun,
To configure the ACE for loadbalancing the following high level steps need to be followed
I don't see from your config attatched that you've configured the ACLs for traffic you wish the ACE to look at. I have found a document that goes through the a basic bridge configuration step by step for the ACE..
cheers,
Chris
03-22-2011 09:07 AM
At a first glance I do not see anything wrong with the config but then again have not worked with ACE for sometime now. Have you verified if the VIP is indeed active? Also is the probe successful? What happens if you try to access the VIP? Also share output of the following commands:
Atif
