Dear guys,
I have problem with Cisco ASR 9006
These log shows over and over below errors, can any one have ever seen it. What should i do now to resolve it?
RP/0/RSP1/CPU0:Jul 8 10:06:14.477 : dumper[58]: %OS-DUMPER-4-SIGSEGV : Thread 2 received SIGSEGV - Segmentation Fault
RP/0/RSP1/CPU0:Jul 8 10:06:14.477 : dumper[58]: %OS-DUMPER-4-SIGSEGV_INFO : Accessed BadAddr 0xffffffff at PC 0xacf7153. Signal code 2 - SEGV_ACCERR. No permission.
RP/0/RSP1/CPU0:Jul 8 10:06:14.477 : dumper[58]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 184447 (pkg/bin/spm_server)
RP/0/RSP1/CPU0:Jul 8 10:06:37.180 : pfm_node_rp[350]: %PLATFORM-USB-2-DEV_EUSB0_NOT_AVAILABLE : Set|umass-enum[32796]|0x1019000|EUSB0 device not available
RP/0/RSP1/CPU0:Jul 8 10:06:46.952 : sysmgr[95]: %OS-SYSMGR-3-ERROR : spm_server(1) (jid 401) exited, will be respawned with a delay (slow-restart)
RP/0/RSP1/CPU0:Jul 8 10:06:46.953 : sysmgr[95]: %OS-SYSMGR-3-ERROR : spm_server(401) (fail count 1) will be respawned in 10 seconds
RP/0/RSP1/CPU0:Jul 8 10:06:50.586 : envmon[206]: %PLATFORM-ENVMON-3-OPERATION_FAIL : Failed in init_obfl_card_temp.4224, error code OBFL temperature initialization failed
RP/0/RSP1/CPU0:Jul 8 10:06:58.044 : dumper[58]: %OS-DUMPER-4-SIGSEGV : Thread 2 received SIGSEGV - Segmentation Fault
RP/0/RSP1/CPU0:Jul 8 10:06:58.044 : dumper[58]: %OS-DUMPER-4-SIGSEGV_INFO : Accessed BadAddr 0xffffffff at PC 0xacf7153. Signal code 2 - SEGV_ACCERR. No permission.
RP/0/RSP1/CPU0:Jul 8 10:06:58.044 : dumper[58]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 213191 (pkg/bin/spm_server)
RP/0/RSP1/CPU0:Jul 8 10:06:58.437 : sysmgr[95]: %OS-SYSMGR-3-ERROR : spm_server(1) (jid 401) exited, will be respawned with a delay (slow-restart)
RP/0/RSP1/CPU0:Jul 8 10:06:58.438 : sysmgr[95]: %OS-SYSMGR-3-ERROR : spm_server(401) (fail count 2) will be respawned in 10 seconds
RP/0/RSP1/CPU0:Jul 8 10:07:01.753 : sysmgr[95]: %OS-SYSMGR-4-MANDATORY_REBOOT_OVERRIDE : mandatory reboot option overridden by request
RP/0/RSP1/CPU0:Jul 8 10:07:03.725 : wdsysmon[445]: %HA-HA_WD-4-DISK_ALARM : A monitored device alarm set by /usb:
RP/0/RSP1/CPU0:Jul 8 10:07:03.739 : wdsysmon[445]: %HA-HA_WD-1-DISK_ALERT : A monitored device /usb: is above 95% utilization. Current utilization = 97. Please remove unwanted user files and configuration rollback points.
RP/0/RSP1/CPU0:Jul 8 10:07:07.729 : x86rmon_fpd_agent[446]: %PLATFORM-UPGRADE_FPD-4-DOWN_REV : rommon instance 0 is down-rev (V10.42), upgrade to (V10.45). Use the "upgrade hw-module fpd" CLI in admin mode.
RP/0/RSP1/CPU0:Jul 8 10:07:09.633 : dumper[58]: %OS-DUMPER-4-SIGSEGV : Thread 2 received SIGSEGV - Segmentation Fault
RP/0/RSP1/CPU0:Jul 8 10:07:09.633 : dumper[58]: %OS-DUMPER-4-SIGSEGV_INFO : Accessed BadAddr 0xffffffff at PC 0xacf7153. Signal code 2 - SEGV_ACCERR. No permission.
RP/0/RSP1/CPU0:Jul 8 10:07:09.633 : dumper[58]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 221439 (pkg/bin/spm_server)
RP/0/RSP1/CPU0:Jul 8 10:07:10.089 : sysmgr[95]: %OS-SYSMGR-3-ERROR : spm_server(1) (jid 401) exited, will be respawned with a delay (slow-restart)
RP/0/RSP1/CPU0:Jul 8 10:07:10.089 : sysmgr[95]: %OS-SYSMGR-3-ERROR : spm_server(401) (fail count 3) will be respawned in 10 seconds
RP/0/RSP1/CPU0:Jul 8 10:07:10.632 : envmon[206]: %PLATFORM-ENVMON-3-OPERATION_FAIL : Failed in init_obfl_card_volt.4996, error code OBFL voltage initialization failed
RP/0/RSP1/CPU0:Jul 8 10:07:21.137 : dumper[58]: %OS-DUMPER-4-SIGSEGV : Thread 2 received SIGSEGV - Segmentation Fault
RP/0/RSP1/CPU0:Jul 8 10:07:21.137 : dumper[58]: %OS-DUMPER-4-SIGSEGV_INFO : Accessed BadAddr 0xffffffff at PC 0xacf7153. Signal code 2 - SEGV_ACCERR. No permission.
RP/0/RSP1/CPU0:Jul 8 10:07:21.137 : dumper[58]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 225535 (pkg/bin/spm_server)
Maybe someone can help me with try to understand this errors and resolve it.
Thanks in advance.
Thomas.
