Automation with Salt or Ansible
romanroma
I am looking into Data Center automation, and I have found Salt and Ansible. Both solutions look promising; however, I am not sure which one is supported greater on Cisco Nexus and Catalyst switches.
Does anyone have stories or what product supports Cisco greater.
Sergiu.Daniluk
In my opinion, Ansible is much better and much easier to use with Nexus devices. I cannot comment too much reg catalyst switches, but I belive is similar story there. You have a lot of modules already existing there: https://docs.ansible.com/ansible/latest/modules/list_of_network_modules.html#nxos plus you can use roles to simplify the deployments.
You can find an example of how I use ansible in my lab to quickly fire up a topology I need https://github.com/msdaniluk/aci_tenantbooks
Here, each inventory file is the config I need to push to my switches (nexus standalone and aci), and the playbook remains the same, through the use of the roles.
Hope it helps,
Sergiu
Sergiu.Daniluk
Hope it helps,
Sergiu
@Sergiu.Daniluk
Thank you again for you help, and detailed posts. I have already installed and just taking small steps with Ansible, so very positive on being able to automate some configurations.
